how to remove the outer cv joint from the axle?
i have a 1988 90 and i needed to replace the driver's side outer CV boot. i separated the joint from the hub, and i'm now lost as to how to separate the CV joint itself from the axle.
this isn't like the newer 90's which have an allen _bolt_. this hub connects to the joint by a _nut_. anyone have a clue here? it seems as if it should be so simple, but it's just not budging.
thanks.
-tim economides
630-768-8797
thanks.
-tim economides
630-768-8797
Re: how to remove the outer cv joint from the axle?
well, here's a bit more of what i've discovered. right as the axle connects to the inner race, there's a plastic washer type thing with a small divit in one side. this rotates independently of the cv joint and the axle. any clue what i should be doing here?
Oh my....
A person should always have referance material for each and every repair attempt....<ul><li><a href="http://volksweb.relitech.com/cvjoints.htm">http://volksweb.relitech.com/cvjoints.htm</a</li></ul>
mikekisss
06-04-2010 07:34 PM
RussB
15
03-08-2003 10:08 AM
computrtutr
12-10-2002 09:26 AM
