HVAC issues...
When I got my 90 a couple months ago, one annoying thing was that the cooling fan ran all the time. I finally figured out that If I pull out the fuse for the HVAC, the fan turns off and runs its normal cycles (with the coolant temp). Nice, but now I have no Heat/Defrost/AC. At the time, I tried unpluging all of the AC connections (high pressure sensor etc..) the fan still ran. So I'm really wondering what this can be. Any ideas? Also with the HVAC plugged in, I only get the high blower fan setting on the dial. How would I fix the rest of the settings to work too? Thanks
then a voltmeter. This, in an effort to determine which component is the problem. Could be the relay? Temp sensor? Rad fan switch? After-run switch? Wiring?
Basically its a process of elimination. ;O)
I know it's something in the HVAC... but thats a good idea to get a wireing diagram. Need a shop manual! (cant find on ebay) The wonderful world of audi wiering! ![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
Thanks
Thanks
radjaco
08-16-2018 03:19 PM
mgcman
Audi 100 / A6 (C4 Platform)
06-22-2006 06:17 AM
Luxus Panzer
9
04-25-2004 10:38 AM
