Hydraulic Schematic of PS/PB for 1990 Coupe Quattro. Leaking plug on hyd pump.
Does anyone have a Hydaulic Schematic of the high pressure Power Steering/ Power Brakes system for a 1990 Coupe Quattro? I have a leak occurring at the screwed in plug on the top of the hydraulic pump. I removed the plug and found that the o-ring gasket was blown. I replaced the o-ring and it blew again right away. Tried a harder ring, and that blew too.
Perhaps the "dump valve" (the hydraulic valve that determines system pressure) is somehow malfunctioning. I was wondering where that valve might be, and was hoping that a hydraulic schematic might shed some light.
Is is part of the Hyrdraulic Pump? Is the spring and plunger under that screwed in plug part of it?
Any info regarding this would be great. I would prefer not to replace the whole pump.
Also - I had this pump replaced about a year and half ago, after the original one froze and broke the shaft. I had a similar leak initially after the new pump was put in, which my serviceman replaced under warranty. It's been good since then, up until 3 days ago.
Jim
Jim
Jimbo.. get anywhere with this? Mine weeps ever so slightly and you clicked off
a few thoughts in my head regarding the pressure of the system. My bomb just sprung a leak not long ago and the thing is fairly new, plus the weep at that plug. So I might need the same info you might have gotten already? What have ya found?
NinetyQ
02-04-2013 04:25 PM
Zwoobah
Audi Original "S" Cars
03-31-2006 08:19 PM
Mercur
01-21-2002 07:01 PM
