I Found the Blink Codes and....
say it blinks 3 times then pauses...
then blinks twice then pauses....
then 4 times and again a pause
then say 3 times with anther pause....
your code would be 3.2.4.3
the pauses are to seperate the numbers.
From memory 4444, means that there are no codes stored in memory. So what might be happening is that you're confusing the start pulse with a one, and so every time you read a new code the "1" moves to the right.
check out this page on the 20V site. I know you don't have a 20V, but it'll point you in the right direction. Good luck....<ul><li><a href="http://www.20v.org/fault.htm">20V.org</a></li></ul>
to little thingy and did it 4 different time so i dont know any other suggestions? Can ya help on telling my why my cr is still not starting?
and so if you get it with other codes, then someting's not right somewhere. Given that all the other codes are 1444, 4144, 4414, 4441 with the "1" moving by 1 position to the right each time I suspect that you're reading them incorrectly....
for those just starting to read this problem the car will not start. after sitting for 12 plus hours it starts and runs fine. after being shut off it will not crank again for 12 plus hours. spark is fine and fuel pump is fine. and ive just pulled the codes to no avail. any help please!
