I need help with a Part Number that Hubturn mention?
#11
You talking about the throttle body to plenum gasket?
![](http://i146.photobucket.com/albums/r259/grillage/7d18cfb6.jpg)
Part number 078 129 949
http://www.ecstuning.com/Search/078129949/ES283683/
Or the plenum itself?
![](http://i146.photobucket.com/albums/r259/grillage/89a07e3d.jpg)
The part number is 078 133 357 F
If its the gasket, try the "telephone cord fix" to improve the seal...
https://www.audiworld.com/forums/sho...35&postcount=9
http://www.fcpeuro.com/products/audi-volkswagen-vw-mass-air-flow-sensor-gasket-a4-quattro-a6-quattro-passat-genuine-078129949c
And the ecs tunning is the correct one that you listed that I was talking about, it seems
#13
When I get time I will pull it off and check to see if the rubber grommets are still attatched to the plastic intake,
I still have to check what engine codes I have since my check engine light comes when driving after about 5 miles steady at 60 mph.
Can I still purchase the 2 rubber grommets if mine are missing I wonder. I'm just having a bad week with everything it seems.
I just did 2 front struts and wheel bearing and pads and rotors all a way around after I replaced the engine, So far I have spent around $1900.00 the last 2 months and that's doing everything myself.
I appreciate the ecs tunning link and will order that gasket seal to be on the safe side.
Thanks for all the help.
Duane, MI
Duane, MI
sofTTware
01-26-2005 06:18 AM
Jretal
12v V6 Discussion
03-16-2004 10:54 AM
