I need help wireing my rear deck speakers?
i am tryin to put in some new speakers in the rear deck. I opened my door panel up and took out the stock speaker...and after that i was very confused how are u suposed to wire a new speaker into that metal fuse box/amp or what ever it is? Dose anyone have any sort of wireing diagram or how did you guys do it?
...rear doors) use a common ground. Both grounds are twisted at the connector on the back of the deck (2 wires into 1 pin).
So you basically want to just remove that whole rear woofer (amp and all) and install your new speaker in its place. If you can, run new wires, if not, you can use the factory wires, but you will need to seperate the common grounds (aftermarket decks do <b>NOT</b> like them).
pat33
07-09-2005 09:13 AM
Always A Blur
11-28-2003 10:37 AM
Ray Tomlinson
04-18-1999 05:31 AM
