Idleing
When ever i go to start my car the hole engine shakes rapidly and the idleing goes down so much to were the car doesnt want to stay started i checked for vacumm leak and i didnt find anything, does anyone have any ideas??
Thanks so much.
Thanks so much.
Search for information about the idle stabilizer valve (ISV) and how to clean it. Also read about how to check your engine's fault codes and address any issues there. Make sure all electrical connectors under the hood are connected (ISF, MAF sensor, etc.).
Im not sure which gen bosch jetronic meckanical fuel injection system you have, but... there is an Idle mixture adjustment and residual pressure adjustment for the KE-Jetronic... on the older jetronics like the M or the MC they even have a idle speed adjustment... the ke is an attemp at electronically sencerd fuel mixture so if you have the ke check both your fpr's both f distributor sensor and the fbr.... look for gas resign around the gasket of the FDPR... firstly check for a vac leak anywhere you see gas resen... norrow it down... its most likily not a fault since your check engine light isn't on but you'll have to verify it with someone who knows your fault codes and can elimanate possible possibilities by the symptoms your 80 is producing... hope this helps... - James
mikekisss
09-20-2009 07:14 PM
k2exoman
12-29-2004 11:43 AM
