If you disconnect the battery instead of connection under dash,
Which has stored energy within, if this is triggered, it can still trigger the igniter of an airbag. To remove the airbag, I believe it states, to disconnect the battery, remove the fuse/relay for the airbag, and disconnect it from the harness from under the dash, should be connected somewhere on the column before it hits the steering wheel.
And as a precaution, always point the airbag away from your body, basically never have it facing your body.
off just a little to move it a few teeth on the spline. Looks like I'll do it the (safe) hard way again
which airbag is this exactly and is there anyway to get rid of the err without replacing the airbag?
NiceS4
03-02-2006 09:05 AM
Hokie - STI avant
9
12-04-2003 08:28 AM
BSCA4
12-18-2002 01:17 PM
