Illustrated 12V Timing Belt / WP / Crank Seal / Cam Seal / Expansion Tank job. No 56k.
#22
Yes
The relief valve is in place to purge any gases (air) that enter the system (due to coolant flush & fill for instance).
Because gas bubbles rise and you burp & bleep the system from the high points (the heater core valve & expansion tank mouth) the gas needs a way to escape "upgwards".
If you put the valve at 6 o'clock you'd quickly build a wall of air behind your thermostat, blocking coolant.
From wikipedia:
Modern engines are run hot, that is, over 80 °C (180 °F), in order to run more efficiently and to reduce the emission of pollutants. Most thermostats have a small bypass hole to vent any gas that might get into the system (e.g., air introduced during coolant replacement). Modern cooling systems contain a relief valve in the form of a spring-loaded radiator pressure cap, with a tube leading to a partially filled expansion reservoir. Owing to the high temperature, the cooling system will become pressurized to a maximum set by the relief valve. The additional pressure increases the boiling point of the coolant above that which it would be at atmospheric pressure.
From wikipedia:
#25
Re: Illustrated 12V Timing Belt / WP / Crank Seal / Cam Seal / Expansion Tank job. No 56k.
Great post---now for some advice with mine!!Please
Audi 80 1992 2.6 12valve Avant--new in New Zealand. I bought it at xmas and its a smooth unit[I have owned 2x 5 cyl and 2x 4 cyl.]
Took a trip 900kms and siezed the power steering
pump,burnt the ribbed belt and had to be towed.
Working in the open ,I managed to get a new
[used]pump and figured out how to get it all back
together.After fitting the accessory belt I noticed that the timing
belt appeared loose.Oh no, i thought --but after starting the engine the belt tightens which tells me that it is hydraulic?Is that so, as some of my readings suggest a similar spring tensioner as the accessory drive has.
Any advice or suggestions please--I will have to get back in there,I know,but I need the kind of inf found on this forum. Thanks
Bob
Bob
#27
rd350
06-27-2007 07:17 PM
Biscuit141
Audi 100 / A6 (C4 Platform)
21
04-15-2007 04:40 PM
90sportin
Audi Original "S" Cars
02-16-2005 04:19 AM
menta
04-22-2004 06:35 AM
Carlos Ramirez
02-11-2003 05:34 AM
