Installing fuel injector seals (Hitachi 7A Injectors)
So I've been tracking down my bad gas mileage/failed emissions issues and found that cylinders 2 & 3 had lots of buildup around the fuel injector seats so I decided to order a full set of new lower injector seals. I thoroughly cleaned the ports and the surrounding areas on the intake manifold.
What can I do to ensure the absolute best seal against leaks? Should they just go in dry or should I use a sealant or something?
TIA,
- Wren
<img src="http://injector.com/images/audi_hitachi.jpg">
TIA,
- Wren
for some stupid *** reason i took the rail off of the IM, means i took out the injectors, hope the seal good :/
I didn't know if gasoline is enough lube and was considering motor oil. But if that's what the Bentley says, that's the way I guess I'm going to do it.
downindenver
Audi allroad
12-24-2008 11:20 AM
Bob Mik22
09-30-2004 06:23 PM
BetterThanVW
05-01-2003 04:19 AM
