instrument cluster compatability q's
The odometer and tripo have recently quit working on my 93 B4 90. I have an extra cluster from an older (i think it was an '88). Anyway I'm not sure if this will work, actually I doubt that it will. I'm thinking however that I may be able to swap the speedometer part? any BTDT on this as I know this is a common issue, or will I have to suck it up and buy a replacement?
never used them, but <a href="http://www.speedometergears.com/">http://www.speedometergears.com/</a> apparently has the proper gear for the Audi odo/trip meter. You've just got a broken tooth on your gear.
Perhaps others can confirm the part number?
In the past I've just stolen a good gear from another cluster.
The problem usually is the little drive gear that is sold on the website referenced below and is easy to replace as well. That way you can keep the original speedo and original odometer with correct mileage.
SeaChiS6
S4 (B8 Platform) Discussion
09-28-2015 07:46 AM
bobbybuyer
9
11-16-2011 11:43 AM
ThetaTau87
03-21-2006 05:26 AM
