Instument panel FUSE
Alright so the instrument cluster fuse was blown in my 1993 90CSQ. However, i tried replacing the fuse several different times(yes i used the right amp) but everytime i replace it, the instrument cluster comes on, but only until i rev the engine up, and then the fuse blows once again, leaving all of the gauges dead. Any Suggestions?
I'm trying to figure out a similar issue with my car. It might be the voltage regulator in the IC or the IC fuse is also inline with the wiring that goes through the trunk. It's common for the trunk wiring harness to break which could be shorting out the fuse.
These are some of the solutions I've found when I STF and posted questions, unfortunatly I still have not been able fix my problem... so if you figure it out please let us know.
4lane
A4 (B8 Platform) Discussion
05-23-2018 12:36 AM
Jimreynolds503
05-22-2017 06:20 AM
MZimm
11-11-2004 01:49 PM
