Just ordered my Euro spec headlamps (B3 Style) Single H4 Housing - Which HID Kit should I order ????
<center><img src="http://www.e-cubed.biz/Scripts/Logs/VoirPhoto.asp?StoreID=21495&ItemID=16392513&am p;Show=1&Format=normal&Language=2&U=rp i"></center><p>I just ordered the euro spec headlamps/harness for B3's and cannot wait to get them!
At the mean time I have been looking at buying a plug and play HID kit since the euros will be less filtered as the US specs. I am wanting to order a Single bulb H4 6000K kit. Yet on the website they have the Single beam kit which is cheaper and then the Dual H4 Beam kit. What is the difference? Does that mean if I get the Dual H4 kit I will use one bulb just like oem and have low/high beams? Thanks!
Please dont do it. You should spend the extra money on RS2 headlights. HID do not increase visiblity much then because the beam pattern is so good.
I have seen hids without projectors before - They are perfectly fine as long as the bulb housing lens to cover from excessive glare.
