Miktip!!!!!! or any one Crank Shaft front oil seal?
Me again, I put the seal in and it still leaked. The alulimum houseing is slightly damaged because of the bolt that hit it. Would it be possible to put gasket glue/sealer in with it. Or wouls that be a bad job?
Re: Give some sealent a try, see what happens! ;O) Only other.........
How long did it take you? We are talking about the front crank seal on a 12 v6 engine? The seal at the bottom of the engine which drives the serp belt.
Crank Shaft front oil seal.
Ya we are talking about the front oil seal on a 5 cylinder 10 valve. It is behind the crankshaft pulley. Timeing belt has to be removed and pulley in order to get to it. I am just going to give the sealer a try now and ill let you know how I get on. Thanks MikTip.
Re: How long?
<center><img src="http://home.ec.rr.com/miktip/tbelt6.jpg"></center><p>The front crank-shaft seal is under alot of other items, which need to be removed to get at! ;O)
I've done it 4 times, because of leaks, and it takes me about 5 hours, because the timing belt has to come out! ;O)
Harzley
02-21-2011 06:33 AM
qezel
03-02-2007 12:19 PM
Me_and_my_GT
10-21-2003 06:39 PM
