MIKTIP!!!!!....called K&N for a Air filter they said...
that there filter drops right into the box...but when I look at the pictures that u guys have there is no box...whats up....am I looking at the right one?
<center><img src="http://home.ec.rr.com/miktip/TheCone2.jpg"></center><p>The "cone" type filter is the "upgrade" everyone does. It replaces the entire airbox. You must remove the entire airbox to install the "cone".
Plus you need a "MAF adapter" to mount the round cone to the MAF.
You can see the MAF adapter as its bolted to the MAF.(black item)
TAP(www.tap1.com) sells a cone "kit" which includes everything you need to install a cone.
The MAF has a flat face, surface where it once mounted to the airbox, like a counter top flat.
The cone is a 3 inch "round" opening. There's no way to mount the round end of the cone to the flat MAF without an adapter.
You could possible "cut" the MAF to make the cone fit, but then the MAF would never be able to bolt back up to the OE airbox!
The one to replace the OEM....does it make a difference in performance (i.e. i know the adapter takes in more air) but the one in the box (K&N)does it make a difference or should I just leave it alone...the sales person said that they take the K&N and add an adapter to it...but if I buy on without the adapter will it fit into the box? hope I'm clear
The airbox is whats the limiting factor.
This is the main reason folks get the "cone".
By removing the airbox, you get a slight performance gain.
What you gain with installing the K&N square panel, is the filter can be cleaned & reinstalled, vise throwing it away every so many miles.
