Miktip, washer sensor question.
<center><img src="http://24.130.42.105/stuff/DSCF0075.JPG"></center><p>sorry to direct this at you but you made a previous post about the washer level sensor, from the book I have found out that hose two wires below to the washer level switch, from what I understand the washer level switch is located inside the tank behind the black plug in the front, correct?, I dont' seem to see any connections on the tank for the plugs. Thank for anyhelp, need to get the rest of the car put together but the warning light is irritating.
Plus the plug, looks to have been there for a while?
Ya might connect the 2 plug together with a wire, see if the light goes out?
Take a very close look at it.
It has the Audi rings on it! ;O)
The book says only certain Audi's had the sensor.
Ones with the "check system" .
