my central locking system stopped working for no reason.
today I turn the key to unlock the doors and only the driver door unlocked and i didn't hear the usually noise it makes. I unlock one of the rear doors from the inside, and then turn the key in the driver door to lock it and the rear door didn't lock. whats wrong, is there i fuse i should check?
If you hear the pump humming, you likely have a broken vacuum line SOMEWHERE. If no pump, the the lock switch in the door may be bad...try the passenger key lock. Good luck.
Many cases it gets crimped and causes a short.
You been having any other wierd electrical problems lately?
The pump is located in the trunk, pass side behind the carpet. Easy to get at. Have someone turn the key and you listen if the pump runs at all.
I had a similar problen before: It was just caused by a bad connector contact of the bi-pressure pump. I fixed mine by wiggling the connector a bit.
bagxlee
12-07-2009 05:19 AM
Slush Puppie
05-09-2007 12:41 PM
egp320i
03-12-2005 06:16 AM
