My front speakers don't work. How can I fix this?
but front speakers aren't too tough to fix. they either don't work due to the tuning of the balance on the head unit or the some wires may have jiggled loose on the speakers. all you have to do is pry off the covers for the speakers, a flat head screw driver will do, and then there is only one phillips head screw holding the speaker in, loosen that screw and see if both wires are on the speaker. If not then simply reconnect the wires.
I've never met an Audi that didnt have something wrong with it!
Mine suffers problems all the time!
Its just I do my own fix'n! So alot of stuff never makes it here. ;o)
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
just pull on the bass **** until it clicks, and twist to the middle (you'll hit a notch). you probably turned the fade all the way to the rear while adjusting the bass. scary isn't it!
That screw to get the speaker out is right next to the windshield and I can't get the screwdriver in there. Do I need to find a one inch phillips screwdriver or something, or just take the windshield out first?
rchallinor
Audi A3 / S3 / RS 3
02-27-2017 06:22 AM
rob_chitown
Audi 100 / A6 (C4 Platform)
08-18-2007 04:11 PM
JD09er
02-01-2002 02:08 PM
kkii9
01-17-2002 12:48 PM
