My uncle's 90s is not getting compression to one cylinder!
Old 12-10-2003, 08:22 PM
goldringer's Avatar
Default My uncle's 90s is not getting compression to one cylinder!
The car runs rough but nevertheless runs. What can be the possible causes?
1993 Audi 90s
Old 12-10-2003, 08:48 PM
SLAB's Avatar
Default what do you mean no compression
did you hook up a compression tester?
if you really have no compression on 1 cyl, then you have a blown head gasket.
Old 12-10-2003, 08:49 PM
goldringer's Avatar
Default yeah...ran a compression test and no compression.
does this = engine rebuild??
Old 12-10-2003, 08:58 PM
Member
kung_fu_4.2's Avatar
probably. Rings or valves go bad occasionally. Does it use coolant?
Old 12-10-2003, 08:59 PM
repeater's Avatar
Default More than likely it's a bent valve.
No compression... By this you mean you got 0 lbs out of it? Sounds like either a bent valve or a valve completely dropped. Not necessarily an engine rebuild at all. Worst case, some head work and new valve(s).
Old 12-10-2003, 09:00 PM
repeater's Avatar
Default Rings normally won't blow out though, sounds like a valve.
Although my Rotax engine on my jet-ski did spit the compression ring into pieces. It was pretty ugly.
Old 12-10-2003, 09:01 PM
Member
Yeah, only hondas and Chryslers usually
Old 12-10-2003, 09:02 PM
repeater's Avatar
Or Rotax :-)
Old 12-10-2003, 09:28 PM
goldringer's Avatar
Default about how much am i looking at $$$??
1 cylinder had absolutely no compression.
BTW: the car is up for sale. 105k miles. Excellent condion (except for the obvious problem)He is asking $2,000 firm If I had the $$$, I would buy it myself and have it fixed (I really miss my previous 90).
Old 12-10-2003, 09:32 PM
repeater's Avatar
Default Well, first you gotta find the problem.
Heads gonna have to come off no matter what. From there, you'll find it'll either be the valve, or a massive headgasket leak, which I'm sure you would have been aware of. I've seen very very very odd occasions of busted cams on some overhead cam engines, but not yet on anything VAG.
Once the heads off and you determine whether it's a bent valve or dropped valve, take it to a local machine shop, they'll fit you with a new valve, guide, or whatever else you need.
First and foremost though, get the head off.
Quick Reply: My uncle's 90s is not getting compression to one cylinder!
