Need a diagram...about to replace the main driveshaft...
Everything else is pretty straight forward 'cept the bolts and mounting bracket for the carrier bearing. Anybody got a pic from the bentley of the drive shaft assembly. I need to see the bolts for the carrier as mine are pretty risted. I want to know excactly whats under the rust so i wont be into more bucks...
Hey audimike20v should have got those bolts off you too....
thanks..
mike90q
thanks..
mike90q
Changing driveshaft...
It's been a long time since I did it, but I think there were only a couple bolts holding that bearing onto the car. I just took those out and if came right down. The biggest problem I had was the exhaust was in the way. I'm not sure about this, but I think the kevlar driveshaft might have been just for the 20v's.
sidespar
04-18-2007 12:02 PM
Gotpancit
01-02-2007 11:36 AM
cdunlap29
06-30-2005 02:21 PM
Anyone replace bolt-in bearing in aluminum uprights? What would I need to remove to get at the bolts
FinickyDriver
06-28-2005 03:30 PM
CharlieGSanD
05-06-2001 02:36 PM
