need help fast...think clutch is done
at a stop sign started to go and car wouldnt move. Tried again and heard a grinding noise. Car wont stall its starting up fine just not moving. any ideas?? pretty sure its the clutch, anything I can try to get it going?
TIA
TIA
but then won't move as you release the clutch, it sounds like a driveline issue. broken cv joint? axle, driveshaft, diff, or transmission. Start with the cheap stuff at the beginning of the list and hope you don't have to get to the end of it to find your problem.
noticed about a month ago under de acceleration around 30mph or so id hear a clunk, searched the forum and remember seeing that as a possible cause. Ill go take a look under the car and see if I notice anything odd.
Also if i put the car in gear and release the clutch i just get what sounds like a spinning bearing.
but if I put in gear and release the clutch the grinding noise seemed to decrease, you just hear something from the front driver side spinning. When I try to get it moving then its a more high pitched noise.
Ato
05-08-2008 06:21 PM
S4@last!::Now B7 RS4
20
01-07-2008 12:38 PM
hudsonfowler
05-26-2002 03:02 AM
