need help with flywheel position
I guess I was a little too hasty in removing my clutch and flywheel assembly as I neglected to mark its position relative to the crank shaft as per the Bentley. Now I find myself wondering how to reinstall it. Is there some way of knowing how to line it up? Does the ignition timing reference pin have a certain position relative to TDC? I guess since there are 6 bolts holding the flywheel on, I have a one in six chance of getting it right, but I don't like those odds to much! Any help would be greatly appreciated.
Ben
Ben
Especially lying under the car, holding the heavy thing up there with one hand, trying to install bolts with the other! BTDT! ;O)
No Bozos!
Check the front crank pulley. It "may" have a small mark on it at TDC, the cam gear may also. If so, then line up the crank pulley to TDC then use the flywheel mark/pointer on the back to match them up.
I use the pulley mark on mine twhen I'm tinkering with the valve timing, it's easier than trying to work with the crank mark.
2low4snow
23
06-05-2006 12:28 PM
