Need Part Number (someone with ETKA access...) on '93 90Q 12v
Car: 1993 90 Quattro, Manual (V6 12v obviously!)
I need the follwing Audi part number
1) Rear Bearing
2) Front Bearing
3) Front Ball Joint
4) Coolant Expansion tank
5) Coolant Expansion tank Cap
6) Coolant Expansion tank Over Flow hose
7) Coolant Expansion tank "Bottom" hose
8) Coolant Expansion tank level sensor
9) Heater Core Lower/Feed Hose
10) Heater Core Upper/Return Hose
CLUTCH
11) Master Cylinder
12) Slave Cylinder
13) Pilot Bearing
14) Pilot Bushing
15) Release Bearing
16) Release Bearing Guide
17) Release Bearing Guide O-Ring
18) Rear Diff L/R Flange Gaskets
19) Hub
20) Heated WW nozzle
21) Brake Booster Vaccum hose (going to the IM with a T check valve halfway)
Lastly, the Audi PN for a 200TQ Brake MC
THANKS!!!
1) Rear Bearing
2) Front Bearing
3) Front Ball Joint
CLUTCH
11) Master Cylinder
12) Slave Cylinder
13) Pilot Bearing
14) Pilot Bushing
15) Release Bearing
19) Hub
THANKS!!!
Re: Need Part Number (someone with ETKA access...) on '93 90Q 12v
1) Rear Bearing 893 407 625
2) Front Bearing 893 498 625 E
3) Front Ball Joint 895 407 365 A
4) Coolant Expansion tank 8A0 121 403 C
5) Coolant Expansion tank Cap 443 121 321
6) Coolant Expansion tank Over Flow hose 8A0 121 107 E
7) Coolant Expansion tank "Bottom" hose 8A0 121 109 A
9) Heater Core Lower/Feed Hose 8A0 819 371 AB
10) Heater Core Upper/Return Hose 8A0 819 373 A
CLUTCH
11) Master Cylinder 893 721 401 D
12) Slave Cylinder 4A0 721 261
13) Pilot Bearing
14) Pilot Bushing
15) Release Bearing 01E 141 165 B
16) Release Bearing Guide 012 141 180 B
17) Release Bearing Guide O-Ring N 903 542 01
18) Rear Diff L/R Flange Gaskets 443 407 309
19) Hub F: 8A0 407 615 B R: 8A0 407 615
20) Heated WW nozzle 8D0 955 968
21) Brake Booster Vaccum hose (going to the IM with a T check valve halfway) 8A1 611 931 AH
Lastly, the Audi PN for a 200TQ Brake MC 447 611 012 up to VIN 44-K-010 001, 441 611 021 A after
CLUTCH
13) Pilot Bearing
14) Pilot Bushing
qfrog Ti20
03-07-2008 07:01 AM
quattro-sport97
12-11-2005 05:00 PM
Blown Nogaro
9
07-15-2003 06:02 PM
Brdman*
Audi 100 / A6 (C4 Platform)
10-17-2002 11:08 AM
