Need Timing belt help
Ok, I changed all belts and waterpump at 140K. Now the car has 210K. I just want someone to tell me a site a the proceedure to changing to Timing belt. I know I have to take the front clip off, but what else. Im also changing all lifters. Car is actually running great, just time for a little maintenance.
Thanks guys,
Anthony '89 90Q
Thanks guys,
Anthony '89 90Q
removing valve cover is straight forward and you can change lifters by lifting up the cam with the timing belt in place.
Is pull the timing belt, then remove the valve cover and unbolt the camshaft. You can just pick up the camshaft and replace all the lifters, then put the camshaft back. Might be a good idea to replace the camshaft seal, and valve cover seal also. Put the valve cover back on then finish your timing belt job.
I replaced the lifters without removing the timing belt and HOLY CRAP that was scary. To get to the first lifter, you have to lift the camshaft nearly 45 degrees, with the timeing belt still on! Definately not recommended.
Ahardy4
12-10-2006 01:22 PM
m4rcus?
Florida Discussion
05-03-2004 04:57 AM
