New Headunit = No rear Speakers??? Extra wire harness... How to make it work??
You need to send them an output from the pre-amp on the new deck (assuming you have one). They also share a common ground, so I just made a little harness from a spare RCA cable I had hanging around.
I asked the same question several months ago. Search should bring up my thread and all relevant wire colors and whatnot.
Good luck.
Good luck.
...into one pin - called a common ground. Separate them, get some RCA plugs and put the right +/- to one plug and the left +/- to the other. Plug them into the rear out RCA jack on your deck and you should be golden (provided you have the remote wire properly hooked up).
