New member with you guessed it, An electrical issue!
Hoping to get some advice from those more knowledgable on audi's than myself. I picked up a 1993 90 quattro for a winter car and I need some help with an electrical issue.
The whole issue is with the instrumnet cluster. The gas gauge and the coolant temperature gauge do not work. Also the odometer worked when I drove it home but now it does not. And there is no back light in the instrument cluster.
Okay so some background. I read about the instrument cluster issues a little and what I could find said that if both the temp gauge and the gas gauge are not working that the voltage regulator is the most likely culprit, I also read that like my other old german car the plastic odometer gears can break causing it to work intermittently or fail completely. So I replaced the voltage regulator and blew the cluster apart only to find that the odometer gears are fine and the voltage regualtor did not fix anything. So what else could cause these problems? How can I fix it?
I am hoping this a relatively common problem and someone on here can help me out.
Thanks
Matt
Thanks
Matt
Tried that, also re-wired the broken wires in the trunk hinge this weekend. Niether of which worked.
I am stumped, as is the rest of the audi community it seems. Hopefully I just have a bum cluster.
Aintscared35
06-24-2018 05:21 PM
The Turtle
07-19-2004 02:56 PM
escargot
Audi Original "S" Cars
05-04-2003 02:03 PM
