no heat
I just replaced my heater core but i still have no heat, it has automatic climate control, both hoses r hot at firewall, and the temp is now in C not F any thoughts.
There should be a secret key combination to switch to degrees F.
If the heater control doors aren't doing the right things, it can prevent you from getting heat.
yes i put the supplied foam around the core. I noticed that on the climate control when i start the car the display reads 74F then it goes to 7.4F the range of adjustment is 2.7-12.7F I think my control is shot what ur opinion?
jnsluft
09-08-2009 09:24 AM
