Noob Questions on 1994 90 CS
Hey all, just picked up a FWD 1994 90 CS with the V6 and auto transmission. My first Audi, so I am learning the ins and out as I go. Got it for $1300 with AC out of commision, but other than that good shape, no rust or tears and only 130K miles, so lots of life left, hopefully. It has new brakes all around, and the last owner replaced the heater core (whew!) so I am good there.
Two quick questions that I have't been able to find good answers for using the search function:
1. Is it normal for the auto trans to give a clunk and an audible chirp when shifting from 3-4 around 40mph? Or should I be looking for parts? Or a failed mount? BTW only happens on that shift, not on any others.
2. Is is possible to fix the backlighting on the automatic climate control panel? during the day you can see the readout because of the reflectivity of the LCD, but at night you can't see anything. Not a huge deal, but the AC doesn't work, so setting it on auto is not very helpful.
Thanks for any help offered!
tranny and see if that helps.Automatics are at best weak links in these cars.I wouldn't be surprised if it's on it's way out.I had to replace the tranny in my 94 cabrio and it had only 115,000 miles.On the other hand my friend has an auto with 200K and never had any problems.
Here's a link to help you replace the bulbs in your climate control.
http://www.audiforum.ca/a4-b5-b6-b7-...4-climate.html
Welcome to the forum and good luck.
I hope you like your car as much as we like ours as they are great cars but you have to want to get your hands dirty.
Thanks for the help, guys. That link for the climate control looks like it should work perfectly, once I get some radio removal tools for the factory cassette/radio. Hmm...while it is out maybe I should just replace it! ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
In reference to the transmission, the code in the spare tire well is "CFS." Does this denote an early 01N transmission or is it some other model? Trying to find a vendor that has a kit with everything, similar to Blauparts cause they don't seem to offer one for the CFS.
Thanks again!
Thanks again!
You could call them and ask them or you can get what you need here........
http://www.germanautoparts.com/Audi/90/Transmission
very good supplier and fast.
All I could find was a clearance kit for the other codes. I found a link you posted in another thread for two kits, the one that is on clearance and the other, which is discontinued, so I bet that is the one I needed. Thanks, however, for the link to German Auto Parts. Their website is super easy to navigate and I have no questions as to what I need when there. They will be getting some business from me for sure.
Have been working on the vacuum hoses as well, there sure are lots of little inch long sections! The one that goes to the black ball at the front of the engine and one that comes off a Y at the top rear of the intake manifold were already off when I got the car, so I figured the rest can't be far behind.
Also, to those who have done the transmission fluid and filter change on their CFS tranny: I did not see a drain plug and fill plug like was shown on the instructions on Blauparts, so can I just assume that this one is similar to old American transmissions in that you drain the fluid by dropping the pan, making world's third biggest mess, and refill by adding through the dipstick tube? Seems logical, but thought I had better ask.
Thanks for hanging in there guys, I am hoping to be self-sufficient pretty soon.
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
quote
YOU ARE CORRECT SIR!!!
Been a while since I did it but I believe you'll have to remove the dipstick tube where it enters the pan.You should take off the little 10mm bolt that holds the upper dip stick tube so when you go to re install to the pan it will be easier to start the nut onto the pan.
I know I had a hard time with that .It requires patience which is not my strong suit.
good luck
good luck
Thanks again!
Thanks again!
The previous owner said he had new front speakers installed, but they sound horrible. Something is not right there, the head unit must be okay as the read speakers sound great. Add that to my search list.
ninsei
09-26-2005 10:49 AM
mapco
11-11-2004 04:55 PM
who here has a nice working 5spd. for a 93-95' 90CS? lookin to do a conversion, Auto fried..........
bmwslayer
01-03-2002 06:34 AM
