Oil pressure
Old 11-21-2002, 07:57 AM
New Member
smwilkins's Avatar
Default Oil pressure
Audi 80 1.8 injection 1998
Above 2000rpm both the oil light and alarm come on. Oil level is fine. Oil is seeping out of 3 spark plug holes. Any ideas?
Many thanks
Old 11-21-2002, 08:06 AM
padriug's Avatar
Tighten the plugs?
Old 11-21-2002, 08:58 AM
Junior Member
Audi-90sGuy's Avatar
Default Maybe not
Be careful if you tighten the plugs.. You could of striped the threads on the block and may need to tap them which is difficult. Besides, if you have oil leaking out of the plugs then your piston seals are either gone or just about to go.
Old 11-21-2002, 07:32 PM
Junior Member
Nervikterklieb's Avatar
Default you've got bad piston rings
that's causing all of your problems.
Blubyu12
09-03-2010 07:28 PM
A4wheelin
9
08-24-2006 10:34 PM
scva4
02-10-2005 05:54 PM
pbev-csq
07-10-2004 07:02 AM
beep-beep
Audi 100 / A6 (C4 Platform)
08-01-2001 09:14 AM
Quick Reply: Oil pressure
