Oil Pressure? I got by 2 prong oil pressure sender in today...
I'm just curious what the "normal" oil pressure should be. When idling, it reads close to 1 on mine. Anything above 2,000 rpm reads between 3-4. Is this normal?
Thanks,
Mike
Thanks,
Mike
Re: Did you install it? If so, how much stuff needed to be removed and what tools?
Oil needs to be drained. I was doing an oil change. If you take the drivers side wheel and the pastic guard underneath off, you should be able to access it when the car is jacked up. It also helps to have the oil filter off. For really easy access take the oil cooler off (just have an new O-ring ready to put it back on).
Mike
Mike
