Oils and capacities
I want to change the trans oil and rear end oil in my 95 90Q. I know that these cars need a non-corrosive oil due to brass gear syncros. My question is can I use the same oil in the transmission and the rear end and how much oil do i need for both the trans and the rear end?
Depending on which brand/type fluid you choose yes you can use in both. motul gear 300 can be used in both just under 3 liters (2.75lt) for the tranny a little over one for the rear diff(1.3lt) So 4 liters should be all you need.
4Driver4
Audi Original "S" Cars
04-19-2005 06:00 PM
Xel
02-07-2003 11:41 PM
Jeff Vader - boscoj
01-06-2003 01:08 PM
