OK, after timing belt is off....installing new one.....
so, the project didnt get completed this weekend due to lack of tools, but for when it does get done, and i get to installing the new timing belt....do i set the timing up w/the cam and crank pulleys while the belt is off?? how exactly does the procedure go to get the new belt on and timed correctly?? oh, btw 5cyl 10V. TIA
...is that it won't run or will run/start horribly. I once did a 10v turbo and was off by one tooth. The ran fine, but every other start would take about 5-10 seconds of cranking. Turns out I turned the engine the wrong way when checking the timing. Lesson learned: always turn engine to the left, ej: turn crank clockwise when looking at front of engine. HTH and good luck.
radioboard
17
10-18-2006 04:23 AM
