Ok....new cap and rotor....no change to the no-start.....
see if you are getting fuel at the right cylinders? Everything is lined up with each other? Are the wire leads in the right sequence from the cap to the plugs?
yes i get spark at all 5.
Whenever it get to op temp, and i shut it down..it doesnt start.
If i try to start it right away, it sputters for a second then shuts down, never to start again till its cold.
Bad fuel pressure somewhere?
if it's the 5 cyl cis bullcrap check for fuel out of the line (undo 1 line on top of the distrib) if you have EF injectors ..pull the rail and crank .. see if it shoots fuel .
...working while its RUNNING.....lol
Is there a cap i can pull? or do i have to pull the whole rail?
AudiSport4000
08-15-2005 06:22 AM
