OK, you 5 lug conversion experts.....help me convert from 4x100!
I am asking in this forum because a bunch of you seem to really know your stuff about going five lug from 4x108.
At this point I am most in need of help with the front. I have searched and read everything I could find on the 4x108 t0 5x112, but I am assuming that it will be different going from 4x100.
The 5x112 pattern would put the lugs right off of (outside) my '84 4000 4 cyl. hubs by a few millimeters. I did not have a spare brake rotor handy to see how much room for play there was, but I would prefer to change as little as possible (doing the swap for a set of wheels, not for a better suspension) so if I could just swap hubs, I'd be very happy.
Any thoughts? The S2 hub seems to be a direct swap for the 4x108 cars (90s). I don't suppose it would work on my car, would it?
Thanks for any ideas you can offer.
-Rob
-Rob
Re: OK, you 5 lug conversion experts.....help me convert from 4x100!
Don't know about the bearing sizes on your car, but on the B3's (at least) they are 84mm front (IIRC) and 75mm in the rear. In addition the hub splines would have to be the same as the splines on your driveshaafts.
- If S2's fit your car, then this setup would probably work, but finding correct rotors may be a challenge.
<a href="https://forums.audiworld.com/9080/msgs/378868.phtml">pt 1</a>
<a href="https://forums.audiworld.com/9080/msgs/395463.phtml">pt 2</a>
HTH
HTH
selfproclaimedv8buff
02-10-2008 12:45 PM
MysteryMachineCoupe
01-31-2008 05:19 AM
ajrettke
06-25-2006 08:30 AM
