opinions on A/C problem
With summer coming, decided to finally work on getting my A/C going on my 90q. When I switch on the A/C, the clutch definitely doesn't engage. I'm awfully tempted to just get a new compressor. I've been looking around at costs, and it looks like $220 is about the best I can do. I could also just try to replace the clutch, but that looks awfully complex, and prone to me breaking something. Looks like the best I can do there is about $110. Anyone have opinions on the best way to do this job?
Re: Its definitely the clutch. It doesn't click on, nor does it spin.
When you say it doesn't spin, do you mean it's ceased an the belt is jusst slipping/squealing around it? There are many reasons why a compressor clutch won't engage, not the least of which would be low refridgerant. I would have the car checked first by an A/C shop.
Take a 12v jumper directly to the clutch, see if that engages it. As Ben's e//s2
says, there are lots of reasons other that the clutch why it might not pull in.
How long has it been since it's worked? If it's not operated for a few years you will end up replacing the compressor anyway as they will rust from accumulated moisture.
I replaced everything on mine a few years back but I did it a piece at a time - fix one issue, something else shows up. The only thing I didn't replace was the evap coil in the dash.
stevecrozz
07-15-2004 02:02 PM
omidius
12v V6 Discussion
05-27-2003 09:35 AM
