Part # Request..
Part # Request..
I need the part #s for the thermoswitch and the speedometer impulse sensor for my 88 80(2.0, auto). Checked the relay, the one I switched it to worked the same as the one in it, so I am assuming the thermoswitch is bad. I am tired of driving without my tach and speedo working, so I need the sensor.. Thank you to whoever may reply!!
Tim
Tim
I found a "thermal switch" for a '88 80 2.0L auto...but there's several part numbers...
...depends which one you need, maybe the description/colors listed below can help you figure it out:
048 919 369 - thermo switch to be used for: cold start valve installation kit - 40/25C, 2 pin, white
035 919 369 D - thermal switch - 25/17C, 2 pin, black - M10X1 - AUTOMATIC
056 919 367 - thermal switch - 17/25C, 2 pin, blue
053 919 521 - thermal switch cylinder head for vehicles with radiator fan run-on - 135/128C M10X1, 1 pin, blue
devinsixtyseven
04-27-2014 06:20 AM
bronxnativ
07-06-2010 05:30 PM
Bmthorn
Audi 100 / A6 (C4 Platform)
08-11-2007 02:33 PM
eglee413
12-12-2004 05:53 AM
