Parting Out Audi 90 1995 quattro
#11
I need the interior guts to the drivers side door handle.
I am not sure what is broken in myne yet as I have not took it apart. I am told it is a common part that breaks (maybee someone here knows)
Symptoms = key goes in key hole, but no resistance is encounterd when key is turned, and no "return spring" action to return key to center. Key also does nothing, does not lock/unlock door.
#16
you need the lock cilinder, spring, carrier, basicly all that stuff
http://www.auto-parts.spb.ru/cat/au/...8h0rB0wWbWmw==
#17
Remove door card: two screws at top outer edges of door, loosen arm rest retainers (two holes on underside of arm rest) with an allen key, third hole in arm rest for another screw. Open silver handle as far as possible you will see a screw inside, remove it. Now the door card can be pulled up and away from the door. Regulater is bolted to frame by two 12/13mm bolts and motor is bolted to frame by 3 smaller nuts.
#18
Audicted - okay got it.
Thought you meant blower under the dash so I wasn't sure what that process had in store for me. Door panels I can take off and need to for someone else anyway who is after some key tumble linkage etc..
Going up Saturday so I'll let you know after the weekend.
#19
