People keep emailing, asking how I got the machined/blueprinted mounts waterproof so here it is...
<center><img src="http://pictureposter.audiworld.com/711/strutmnt11.jpg"></center><p>
After all machine work is done for the bearing mating surface "flatness" and aligning the thru-bore concentric and on-axis with the bearing I flip mount over in the lathe. Then I machine an o-ring groove in the top of the mount floor that surrounds the slotted nut and when o-ring gets compressed it seals the gap between slotted nut and mount bore. When cupped washer or one of the hardened spacers is slipped over the shocks threaded shaft and tightened down it compresses the o-ring a "planned" compression amount that forms a dust, dirt, debris and waterproof seal that "should" be water-proof to approx 100 meters if my math is correct.
The bearing from the factory has an internal seal on its pivot race on the bottom side and I press the bearing back into the mount using a long-life adhesive/sealant around the bearing so nothing can get inside and contaminate the bearings internals from either above or below the bearing.
Pics worth a thousand words so here ya go.
VAP
05-11-2007 10:25 AM
VAP
23
02-07-2005 06:54 PM
VAP
9
12-20-2004 02:01 PM
DuTTCH
05-06-2004 02:25 PM
