Porsche 996 brakes on a coupe
I know this has been done on other sites such as the S2forum.com, but all those cars already have 5X112 hubs on them. I noticed a few threads earlier it being stated that RS2 carriers do not fit on a coupe. I believe this will dispell that notion. This will also answer some questions others may have.
I also know that that this set up will work with the 4X108 hubs if you can find a rotor with only 5 holes instead of 10. I used a Brembo rotor because it was readily available, but the Ate site shows this rotor with only 5 holes. Have the rotors redrilled and bingo, big brakes on a 4X108 without the expense of hubs. Cheaper to drill rotors.
I have put this on Socaleuro.com because that site is easier to put pictures on and do a write up in between the pictures.
I will also put the pictures on my picture post, but it will not have the write up.
Greg<ul><li><a href="http://www.socalivw.com/forum/topic.aspx?author_id=80&topic_id=24574&cat egory_id=7">http://www.socalivw.com/forum/topic.aspx?author_id=80&topic_id=24574&cat egory_id=7</a</li></ul>
Re: Porsche 996 brakes on a coupe
No no no...RS2 carriers DO fit on the CQ wheel bearing housing. No one ever said they didn't. The only thing I commented on, was that I thought the monoblocs used different mounting points than the 968CS/993 two-piece calipers, parallel to the rotor vs perpendicular to the rotor. It's been a while since I've picked up a monobloc (it was from a 986 2.5L).
HUH?
I've had this setup for 5 years!!
<img src="http://expert.ics.purdue.edu/~fergusoe/Brake_Suspension_small.jpg">
MikTip's had big brakes for a while too. RPI sells kits even!
Re: Correct, they do interfere.
Also, if you do drill the rotor for 4x108, weld one of the 5 existing holes over first, then make sure the mounting surfaces are flat (machine the excess weld off).
