Question about fog light mod...
There appear to be 2 mods... the "tech" mod, and the "MikTip" mod (I found the "MikTip" mod in a post MikTip made). The "MikTip" mod involves jumping pins 11 & 13 where the fog relay once was. The "tech" mod involves 3 pages of stuff including taking the radio out and some other crap.
What does the "MikTip" mod accomplish? Also, all the relays in my fuse box are labeled in German; which one do I pull?
Thanks,
Mike.
Thanks,
Mike.
jumpering the pins where the relay was allows you to have the fogs on without the headlights on. The other "tech" mod allows you to turn on the REAR fog without the fronts comming on. For more info goto 20v.org and follow the instructions there. I only jumpered the pins. One I did not want to pull all that junk out. Second I allways have the front fogs on. So it's not a big deal if they come on when I turn on the back ones. Did have one time that it could have have help though. Snowing relly hard and the front fogs blinded back at you. But deffently the kind of wether that rear fogs were made for. Keep the rear fogs on most of the time in the winter. They melt the snow off the rear lights.<ul><li><a href="http://20v.org">http://20v.org</a</li></ul>
I installed driving lights there, hooked up to the stock switch (using stock wiring). They are brighter than high beams. I want to be able to flash tailgaters behind me without blinding the guy in front.
Guess I should do the 3 page mod.
Thanks,
Mike.
Thanks,
Mike.
<ul><li><a href="https://www.audiworld.com/tech/content_ext.shtml">https://www.audiworld.com/tech/content_ext.shtml</a</li></ul>
duplicate147489
18
12-08-2006 05:04 AM
4rings2turbos
02-03-2006 03:58 AM
AthruC
06-18-2004 08:00 PM
