Radiator fans constantly running
#22
Let me know what resolves your issue, I'm having the same one. I'm going to try replacing the relays and the sensor.
#24
Hey doucy2 just to let you know I removed the lower knee bolster (under the steering wheel) there were just four screws. The relay panel diagram is on the back of the bolster. Some spots were open so I counted over the number of spots, not the number of relays, spot 17 had a relay with the #205 on it. I removed I and connected the battery and the fans did not turn on. I tapped the relay on the ground several times and replaced it. The fans stayed off. I turned on the A/C and the fans turned on, turned off the A/C and fans went off. Restarted car and all worked as it should for now. Keeping fingers crossed, rjjpff, good luck.
#25
popdemonic
Audi Original "S" Cars
12
02-18-2007 09:00 AM
