rear control arm bushings started to "squeak"
I hosed all the rubber I could visually see with silicone spray to give the old rubber some lube but it still did not help.
I can only guess then the upper damper on the shock towers is dry and rubbing.
to totally replace all the bushings on the rear I tallied up about $200 through GVW and then the labor to r/r it all...well it will be a good few hundred unless you have your own press, etc.
*shoulder shrug*<ul><li><a href="http://cgi.ebay.com/ebaymotors/New-Audi-90-A4-S4-Rear-Sway-Bar-Stabilizer-Link-Links_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1423Q7c39Q3 a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q 2ec0Q2em14QQhashZitem350102986008QQitemZ3501029860 08">
