rear diff mount/rabbit-golf motor mount part number - is this the right one?
#11
which direction should the mount bolt offset be facing?
towards the rear bumper or towards the tranny??
does it make any difference?
#15
from the 20v.org archive:
"...> > A brief follow-up... I installed rubber mount 171 199 214D on
> > the rear diff, rear position in my 1990 CQ. It fit perfectly.
> > The part has 64.4 outer diameter, and 38 or 40mm length.
> > The bolt-hole's centerline is offset from the bushing's
> > centerline by about 8.0mm. I pressed the bushing in with the
> > bolt-hole located toward the back; away from the axle, toward
> > the rear bumper. Whereas the bolt was originally toward the
> > middle or forward in the subframe slot, now the bolt simply
> > sits toward the rear of the slot.
> > Looks good to me, and it did away with some of the clunks from
> > the driveline.
> > Jim Fraser
> > 1990 CQ"
perhaps the mount you recieved was not the "D" (aka 64.4mm) one?
> > the driveline.
> > Jim Fraser
> > 1990 CQ"
#16
You'll know what i'm talking about.
If it works for you, all the power to you.
#17
Including a mechanic that works on Audi's for a living.
The 4kq uses the "same" rear subframe as the B3's, same side mounts, same rear diff case, etc.
The 214D part has an "eccentric" center bolt hole, as does the factory all-in-one mount.
I fail to see why it wouldn't work. Why don't you enlighten us?
dtompsett
03-02-2007 10:48 AM
Tom Faust
02-27-2005 05:00 PM
OldSkewS4
10-03-2003 09:08 AM
djtalon
01-07-2002 01:10 PM
