Rear fog/reverse light question
Old 12-13-2004, 10:50 PM
New Member
PearlB3SlowPoke's Avatar
Default Rear fog/reverse light question
Probably a stupid question but I figured I would ask it anyways, lol. Is it possible to fit a H3 HID bulb into the rear foglight spot? Has anyone done this? Will the bulb be to hot for the lense? I just had someone get right on my *** tonight on a pretty steep hill. I was thinking a little HID reverse fog action would learn them good
Old 12-13-2004, 11:06 PM
SCarGo02's Avatar
Default My Seima/Tresser tails actually have a H3 fog light socket... [edit]
...as of right now I have a 55W H3 bulb in there, although, I don't keep it on, for fear that it might melt the lens/housing.
I haven't been able to find a lesser wattage bulb, so, I'm thinking it's meant for that wattage...who knows...
The housing for that bulb is different than other tail lights though, as there's a reflector in the section for the fog light.
So without completly "hacking" the taillight, I don't know if it really is possible to add a H3 socket/reflector...
When I get back home tomorrow I'll post a picture or two of the socket (I took them because I asked other forum member with tinted tails if they had this socket, but none did -- but they have the Hella tails, not Seima).
Old 12-13-2004, 11:08 PM
AudiWorld Expert
quattro.pilot's Avatar
Default prolly too much work to make fit. Tresser/Siema tailamps came stock with an H3 rear fog
check out SCarGo02's picposter... he has these unique tailamps on his B4, and I think he has pictures in his account.
otherwise I think it'd be too much of a PITA to bother thinking about. But then again, anything is possible ;-)
check yah later
Old 12-13-2004, 11:09 PM
New Member
Default I will have.........
to take a look at my tails. Should be the same as I have the same tails as you, I think.
Now I am not much of a headlight/bulb guy but do HID bulbs burn hotter than regular bulbs? Would it melt the lense if it was only for only a few seconds? I really just want to do this as a "get off my ***" light.
Old 12-13-2004, 11:10 PM
AudiWorld Expert
HID is typically thought to be "cooler" than regular filament/halogen bulbs
Old 12-13-2004, 11:11 PM
SCarGo02's Avatar
Default If you have Hella tails, you probably don't have the H3 socket as they only seem to be in the Seimas
Also, I *think* this is only for Seima B4 tails, although, I could be wrong.
SCarGo02's Avatar
But would still be a pain to properly retrofit....
New Member
Default I have those same tails on my b3.
You can see the pics in my "folder".
Old 12-13-2004, 11:12 PM
SCarGo02's Avatar
Are they Seima or Hella? And you have a B3, not a B4 (right?), so they're not the same tails...
Old 12-13-2004, 11:13 PM
New Member
Default Hmmmm........
I will have to take a look tomorrow. I have a few halogen h3 bulbs lying around. Will have to see how hard it would be to make it fit. Doesnt need to be pretty or anything just stay in place.
Quick Reply: Rear fog/reverse light question
