Rear speaker replacement.
I'm trying to replace my stock speakers that came with the 94 Audi 90 CS. The wiring harness is not like what I've seen before. No regular male and female wiring. Anyone run into this and change us the wiring? How did you do it ? And pic would be very helpful, for me to see what you did.
If you absolutely do not want to run new wires to the rear speakers you can tap into the wires in the red connector behind the radio. This connector was for the original self-amplified speakers. There is a pair of wires you can use for each side. They are fairly small gauge, but work fine for a normal system. The green wires in the Brown connector go to the Front speakers.
The job is made easier if you get a aftermarket to factory harness.
I did this years ago when I put a JVC headunit it. Mostly plug and play and easy to remove/update if you use 3M male/female snap connectors.
<a href="http://tinypic.com?ref=oksytj" target="_blank"><img src="http://i43.tinypic.com/oksytj.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Audi Other Audi RS2 (recreation) for sale
Georgi_Kirov
09-15-2015 11:11 PM
elem
09-02-2015 02:20 AM
