Rear spring perch question!
I have been talking to BLAU's tech regarding my rear setup being way higher than the fronts. He suggested to look at the spring perch to see if it was positioned upside down.
Can anyone of you who's running Bilstein sport setup recall if the perch in this picture is in the right position? If I were to flip it around, do you think it will lower the height a little? I am really only asking a litte drop because it's frustrating to look at it being uneven...
The shop that installed it said they've already put it it on the last groove where the perch sits...
TIA :~(
<img src="http://pictureposter.audiworld.com/42826/dsc00636.jpg">
TIA :~(
Looks right to me and also looks like your not looking at any drop if you turn it around inless
putting it the other way masteriously shifts the holder down further, also dont trust my opinion im just observing
It looks like you have it right. I know it's no help but you can.....
<center><img src="http://ctny.audiworld.com/mark/s4/suspension/dsc02613.jpg"></center><p>send your shocks to Bilstein and they'll make you grooves where ever you want for ~15.00 bucks each.
your perch is correct. You have two choices: live with it as-is or have another groove...
turned into the rear shocks that are 10-12mm lower. There is no other choice. "carless" or as-is. Your call. A local machine shop could do it but not for $15 each. Prolly $50 for both as they're gonna get one hour and work at a one hour "minumum."
