rs2 headlight adjuster issue
i cant adjust my driver side headlights with the adjuster. when i turn the adjuster screw nothing happens with the light beam in movement up/down or left/right. what gives?
i havent found anything on fixing them in my search but i did find that there is an adjustment for the low beam and the high beam?
i didnt know that you can adjust the high beam independly (sp?) from the low beams?
i see there are 2 adjuster screws. the outter screw (close to the fenders) are for the height adjustment and the inner screw are for the side to side adjustment correct?
The high and low thing is wrong info.
I can tell you that I had a similar question and found that the up/down screw (the one on the outside part of the headlights, IIRC)is reaaaally slow to adjust the height. You just have to spin it a bunch.
