RS2 vs H4/H1 headlight beam pattern
Ok so I am stuck with this H4/H1 headlight when I thought I was getting a RS2.. question is does one or the other do a better job of lighting up the road?
<img src="http://mail.chartermi.net/~timd/h4h1lamp.jpg">
<img src="http://mail.chartermi.net/~timd/rs2lamp.jpg">
That E-bay add was a ovious lie. You did not get the item described. Contact E-Bay as they are verry good with this kind of thing. They will hook you up under a fraud case. If you paid via Credit Card, your credit card company might also help you out under a fraud basis, Good luck!!
he has received alot of emails from many of you guys looking for more RS2 lights, and because this putz can't tell the difference between a H4H1 light and and RS2 light, he is more than happy to take this one back and resell to one of you for more money....
doh... think I'll just hang onto it than have anymore dealings with him. Just the fact that he won't admit to a mistake or wrongdoing just pisses me off. (or even that there is a difference between the lights)
H1-H4: low beam
<img src="http://pictureposter.audiworld.com/53503/h1-h4_lowbeam.jpg">
RS2 low beam:
<img src="http://pictureposter.audiworld.com/53503/h1-h1_lowbeam.jpg">
H1-H4 high beam:
<img src="http://pictureposter.audiworld.com/53503/h1-h4_highbeam.jpg">
RS2 high beam:
<img src="http://pictureposter.audiworld.com/53503/h1-h1_highbeam.jpg">
hope this helps. Keep in mind, with the RS2 you can wire it so that both bulbs are on for the "highbeam" It looks something like this:
<img src="http://pictureposter.audiworld.com/53503/h1-h1_highbeam_both_bulbs.jpg">
I think the differences are evident on their own.
check yah later
RS2 low beam:
H1-H4 high beam:
RS2 high beam:
check yah later
do you WANT me to proove it with pictures??? I've already offered once.
We'll play "guess the backside of the lamp", where you goons try and figure out which one is the H1-H4 & RS2. If you loose I get all jo sheit.
