RS2 wiring harness -- is the harness still used once you upgrade to HID or Xenon ?
Does one wiring harness do a 'pair' of lights or does the wiring harness refer to a 'pair' of harnesses as standard when ordering?
what happens is that you keep the rs2 wiring and you just connect the hid bulbs and ballasts to the wiring,(via the rs2 headlamps since the plugs are there)and then you just give power to the hid system connecting an earth and positive pole somewhere.
you do nothing to the wiring of the headlamps,unless you have a check system,which in that case if you use hids you may be getting a burnt bulb signal,if you get to that,we'll talk again! hehe
ProtoColD
09-09-2003 05:05 PM
Couper
11-13-2001 05:46 AM
