Rubber Seal on Throttle Body
Hi,
Does anyone know the part number for the rubber seal that goes between the throttle body and plastic housing where the rocker breather pipes join?
I rang Audi and they cannot locate the item and have suggested I go down to look on their screen.
I am not sure if this would be an Audi only part or if it may be available elsewhere.
I have loads of movement on mine and I suspect it is sucking air from this point.
Rodney
Rodney
Hi sir.
Don't know the number but (it may be search-able here, or at say 'arizona autohauz.com') below you will find a photo.
Your suspicions are both correct. A well known leaker when aged.
Not on my computer right now so I can't link you direct but try this:
Go Advanced Search, Keyword: 'Tour', User Name: 'Lago Blue', Search in Forum(s): "12v V6 Discussion'; then press 'Search Now'.
See post #9 and it's two links going back (I'm afraid it's still an incomplete tour).
Hope that helps.
Hope that helps.
Seneb
09-08-2006 03:59 AM
Gjaime
04-26-2004 11:56 AM
